Euro currency symbol into numeric control
I am trying to get the euro currency sumbol € into a numeric control (formatting code '€ %0.2f'). I cannot get this to work, it is replaced by some ASCII graphic....
The symbol seems to work in a string.  But using it in a formatting/constant string gives very strange responses. e.g. :
(1) make a string indicator with correct symbol and copy it as constant, now the ASCII graphic appears
(2) Make a format string and use 'format string' to convert it, now again ASCII graphic
(3) Use a euro currency symbol as input string, now again ASCII graphic
(4) Use the euro currency directly as string constant to an indicator, now again ASCII graphic
(see attach)
I can't find anything about this issue on the NI website, anyone has any suggestions how to proceed (except using 'Eur' instead) ??
Using LV8.6 on XP
Kind regards,
Mark
25+ years long fan of LabVIEW. Move to Emerson looks to be for the better! See the last posts in subscription model thread.
(3,427 Views)
I replaced your euro sign with mine and it seems to work. Don't ask me why...
LV 2011, Win7
(3,418 Views)
Accepted by topic author beuvink
I just realized you have 8.6...
LV 2011, Win7
(3,417 Views)
I can open yours as well, this works perfect.
Probably something wrong with my euro sign (ALT-0128) and something good with yours.
I see some differences in hex code and I will check the difference.
Thanx for the quick response!
(3,413 Views)
