Eurotherm 3216 slow DAQ rate
Dear all,
I am happy to be a new member of the NI community.
I am struggling with data acquisition of 3216 Eurotherm temperature controller.
I have 4 3216´s connected to my PC with a RS485 converter.
When I use iTools OPC server I can log e.g. the temperature with a sample rate of 1s into a txt file, that is fine.
But if I do that with the provided LabVIEW VIs from Eurotherm_32xx_series, I reach at most 2s sample rate.
I use "Read Process Variables.vi" for unit address 1 to 4 and pass the 4 element array with a timestamp in a queue to a consumer loop.
MOJO
(2,370 Views)
You should attach actual VI's so we can see how it is programmed.  I don't know how you can expect us to help troubleshoot something we can't see.
(2,338 Views)
You are right. Please find attached the code section with Eurotherm code and open Eurotherm_3216.vi as main.vi.
The 3216 controllers are one of many devices that are controlled in a NI QMH structure, each device in its own message handling loop.
(2,321 Views)
