Eurotherm 3216
I am using Labview to control two Eurotherm controllers, one controls the oven temperature while the other controls mass flow controllers. I used the attached vi to control the set point. The vi works but when it comes to the mass flow controller how to remove the indication of degree celsius. Which sub vi or driver needs to be fixed in order to delete the indication.
Message 1 of 1
(2,240 Views)
