Eurotherm 3504
Hi All,
I am communicating with 4 eurotherm 3504 controllers using separate USB to serial converters. I am using the ET3500.lib drivers. I have the comms with each device in separate while loops which on other machines means I can communicate with up to 4 eurotherms every 100 ms of so.  On this machine it is taking over 600 ms. It seems when I communicate with 1 eurotherm it can run every 100 ms but as soon as I add the other is slows down. It seems as though all the comms are going through one port. Any help would be appretiated. Also for the first time in 30 years using labview it is crashing! I am using labview 2020.
Julian
Message 1 of 1
(360 Views)
