Eval Formula Node
All,
I'm trying to eval y=min(x,5) using the "eval formula node" with no luck (other functions works great). Ill appreciate any input.
thanks, Erez
Message 1 of 13
(4,811 Views)
Hi Erez,
why do you need an "eval formula node"?
Message 2 of 13
(4,807 Views)
@erezg wrote:
All,
thanks, Erez
If you look in the sub VI "NI_Gmath.lvlib:Function Decomposition.VI", You'll notice min and max are not functions that are supported.
Message 3 of 13
(4,764 Views)
@GerdW wrote:
Hi Erez,
One reason to use eval formula node (the VI, not the formula node), is to get a function as a string from a configuration file....
I guess most of us made replacements...
Message 4 of 13
(4,759 Views)
thanks for the help 🙂
I guess Ill have to use a replacement as well.
Message 5 of 13
(4,708 Views)
I can highly recommend Dijkstra's Shunting-yard_algorithm as a starting point.
Not easy, but a lot easier that figuring it all out yourself.
Of course, someone might share a solution...
Message 6 of 13
(4,701 Views)
BTW, is there a way to add the max/min to the function decomposition?
thanks
Message 7 of 13
(4,621 Views)
I looked inside the eval function, and it looks like the final calculation is performed in
"three register calculation.vi" (all the allowed function are there). I tried to relapse the "+" with "min", but with no luck.
Any idea?
Message 8 of 13
(4,616 Views)
@erezg wrote:
Any idea?
Keep trying?
I won't start with replacing the + with min. + is an operator, not a function. I'd start with replacing a 2 parameter function, Or a 1 parameter function if there isn't one. This will be closer to what you want. Next step would be to add the function in stead of replacing it. This needs to be don in two places. The parsing, and the execution.
Message 9 of 13
(4,604 Views)
wiebe@CARYA wrote:
@erezg wrote:
Any idea?
I won't start with replacing the + with min. + is an operator, not a function. I'd start with replacing a 2 parameter function, …
I recommend to start with creating a copy of all those VIs from vi.lib before even thinking about editing them!
(Ofcourse only edit the copied VIs, not the ones from vi.lib!)
Message 10 of 13
(4,599 Views)
