Evaluate how red the pixels are in an image
Thank you so much for the help! The DLL version worked perfectly. In my CPU environment, it took 70 ms to convert the image with the 8-threads MSVC DLL. I will spend some more time to understand what it does. Thank you again.
Message 11 of 12
(263 Views)
Glad to see, it was helpful for you. I would to recommend at least be able to re-compile the given source code (you can take almost any available C Compiler which can build 64-bit DLL).
Message 12 of 12
(244 Views)
