Evaluation copy message on 3d graph
    I am using a 3d graph in one of my programs. It works fine on one computer. When I transferred the entire code to another computer and opened it up, the 3d graph displays the message "Evaluation Copy" on it.  What should I do now?
Thanks.
(3,112 Views)
I think this means that you don't have a validated version of LabVIEW installed.   Search for help on "Activating LabVIEW Software"
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(3,105 Views)
I do have a registered version of labview . I don't have any similar problem with anything else in labview
(3,094 Views)
Hi arbit,
What is the version of LabView you have?  There was an issue like this in the past that is version specific, so perhaps it may be related.
(3,072 Views)
I have labview 6.1 on both computers.
(3,065 Views)
Bingo.  A few more questions to narrow down the answer.
Did you have the beta version of Measurement Studio 6.0 or LabView 6.1 installed on your computer in the past?
Do you know if your version of LabView is the base edition, the full development, or the professional edition?
The base version only installs an evaluation version of 3D graphs, so this is the expected behavior.  If you have installed a full or professional version of LabVIEW, then you should have a fully registered license for the 3D graph and should not be encountering this behavior.  Once I have your answer for the first question, we can go through a step to make sure that this behavior is fixed.
(3,060 Views)
