Evaluation does not work
m-s wrote:
I got some strange errors myself when I installed the first time. Try reinstalling. Or download it again. Maybe your file was corrupted.
 What kind of strange errors did you get ? I have tried reinstalling with a fresh download. No go.
Message 11 of 20
(2,010 Views)
Mathan wrote:
Have you changed your system date? That might be the problem?
I do not mess with my OS. Its mac, you know 🙂
Message 12 of 20
(2,010 Views)
muks wrote:
Jerry,
Did you sort it out?
No. I have tried downloading and reinstalling. Then I installed AppCleaner and tried to install and remove. Fresh install after that still gives the same error. Maybe labview does not work on mac.
Message 13 of 20
(2,010 Views)
I downloaded the trial today. The install failed initially (low disk space) but completed ok. Now it gives me this error. I am using an iMac.
Message 14 of 20
(1,994 Views)
I had trouble removing the evaluation because it did not have an uninstaller.
This is new and troubling.
Message 15 of 20
(1,974 Views)
Use msi blast
Message 16 of 20
(1,962 Views)
?Can msi blast be used on a non-widows operating system?
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 17 of 20
(1,958 Views)
The uninstaller entry is named "National Instruments software". Click "Change/remove" and select the LabVIEW version.
Message 18 of 20
(1,956 Views)
Hello JerryV, currently Snow Leopard is not yet supported by LabVIEW 2009. We have tested and supported up to Mac 10.5. We have not yet projected when exactly we will move to 10.6.x but its on the roadmap.
For other members on this forum, has anyone had issues using the evaluation software with Mac 10.5 or earlier versions? Please let me know.
Anna K.
Message 19 of 20
(1,931 Views)
Snow Leopard may not be supported. However, IIRC, the development system works fine with the evaluation version on 10.6 as well as 10.5. I think that the instrument drivers do not work.
Message 20 of 20
(1,929 Views)
