Event Based: Overwrite default message as soon as user initiated command and send periodically
Ok Gerd.
In real scenario there are no. of user commands such as brake mode bit is set 1, so once set it will send the message along with brake mode bit periodically, but earlier it is being sent as 0 in default message.
I got your point.
Thanks for sorting it out, i will try, and update you on the same.
Message 11 of 11
(257 Views)
