Event Callback Problems during compilation
Hi
I try to register a callback vi with the "Register Event Callback"-node. I
pass a reference of an array as user parameter into to the "Register Event
Callback"-node. Everything works well in the development environment. But
when I try to build an executable I get the Error "1003 . The vi is not
executable".
What is wrong?
Mareike
(3,039 Views)
Hello Mareike,
you can surch in the http://www.ni.com/support/ for "error" and "1003". There you will find a lot of links where this error is discussed. With a little luck, there will be an answer.
Regards ThomasD
(3,037 Views)
