Event Capture
In my application I am monitoring a series of sensors that are binary on or off. I need to somehow capture the event where one sensor goes from on to off. Any advice on how this can be done? I'm running LabVIEW 7.1 and windows 2000
J
(3,752 Views)
hi,
You must be using some D I/O card to monitor these sensors,so all you have to do is use the read D I/O vi and get the status of the sensor and use a simple case loop for any action to be taken when the sensors go High or Low.
Hope this helps
cheers
vicky
(3,743 Views)
Just do a AND operation between the previous value of the sensor ant NOT the new value. See the attached example.
CC
Chilly Charly    (aka CC)
(3,742 Views)
Check out my recent answer to a similar question.
(3,737 Views)
