Event Programming with Digital I/O
Can an Event Structure be used with digital I/O?  All of the examples I have seen show the Event Structure being used with the keyboard or mouse.  But have not found any examples showing the Event Structure being used with digital input.  Mainly I am looking for a link to an example. But any help you can provide will be appreciated.
Howard.
(2,860 Views)
Accepted by topic author hrh1818
Yes, you can register for some DAQmx Events.  Look in the Measurement I/O -> DAQmx Data Acquisition -> Advanced -> DAQmx Events palette to get started, or run a search for DAQmx Events.  Not all DAQmx devices support Change Detection events, which is most likely what you want if you're doing digital I/O, so check that it's supported by your device.
(2,858 Views)
