Event Structure Edit Window
I am using LabVIEW 2013. When I place an event structure on the BD and right clikc and 'Add Event Case' or 'Edit Events Handled by This Case' the Edit Events window does not pop up.  An animation happens like it has opened up but the window is no where to be seen.  If I try to click anywhere else in labview my computer just beeps at me like the window is open and I'm clicking outside of it. If I press Esc I can get back to my BD and continue as normal. Unfortunately I can't edit my events.  Any ideas? Is there some option I may have changed that is making this happen?
Thank you for any help
Jesse Zamora
P.S. This is happening in a VI I started this morning and it also happens in a new VI.
(4,332 Views)
Accepted by topic author JesseZamora
Close LabVIEW
Look in LabVIEW.ini for "EditEventsDlgSize="
delete the line.
you should have much joy.  (this appears to be a known issue)
(4,323 Views)
Thank you so much.
Jesse
(4,319 Views)
thank you, this is correct answer for the problem on my computer...
(4,184 Views)
