Event Structure Execution
Thanks for the two methods of solving this.  I'd like to use the first one but just can't quite figure out how to create it.  Could you possibly provide a simple example that would represent using a couple of solenoids?  I plan to control several solenoids but this would at least give me a better idea how to do it.  Thanks so much for your help.
Message 11 of 13
(989 Views)
JHess,
I started a Queue - Dequeue method.  In order for it to work, you need to have the correct task name for your digital output to each solenoid.  I hope this helps.
I made an error in the producer vi!  You need to wire the error from the producer to the for loop to delay the for loop until after you push the stop button!
Tom
Message Edited by Tom Haggerty on 01-29-2008 07:33 AM
Message 12 of 13
(977 Views)
This is corrected.
Tom
Message 13 of 13
(972 Views)
