Event Structure Issue
I just started having this issue today out of nowhere.  Anytime I try to add a new event to my event structure in the producer of a state machine Labview freezes up on me.  Whenever I use the task manager to end the program I get a message stating that Labview is waiting for a  response from me.  After seeing this I tried again and hit enter when Labview froze again.  It added an event without any cases and without displaying the Edit window that usually would pop up.  I have tried restarting my computer and repairing Labview, but nothing so far has alleviated the problem.  Any help would be appreciated.  Thank You.
(2,891 Views)
Your event cofiguration seems to appear at an offscreen location and you cannot intereact with it. did you e.g. use a dual monitor setup recently?
This was discussed here before, and I think all you need to do is delete the relevant line from the LabVIEW.ini file.
(2,888 Views)
