Event Structure auto and manul mode
Hello all
I trying to make automatic event in my code but some how is not working please have look.
task is :
in string array i have "manual" and "auto" strings when auto string is present event structure should be triggered automatically when manual string is present the event structure should be triggered by 'next step' button.
(3,090 Views)
Why Event?
see code
If you need notify change to Event structure, you need val(signaling) property (see bottom line)
(3,076 Views)
Your code has many problems.
  1. You are using the event structure incorrectly. (Timeout not needed)
  2. You have a race condition with the "mode" indicator.
  3. Too many sequence structures (you have one!)
  4. All buttons should be handled in the event structure
But the big one is number 2. That is why it isn't working as you expected. The problem is that the mode indicator is read in parallel with the execution of the event structure - which is where the mode indicator value is set. Consequently, the indicator is read before it is set. Dataflow!
Recommend that you take a LV training class, live or online.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,071 Views)
