Event Structure driven menu
Event structure are quite new for me. But I realized that they are a good solution to manage user command on the front panel. I am currently building an application and I would like to use Event Structure. But I would also like to use them in an appropriate way.
I would like to know what is the best way to use Event Structure.
Do I create an Event Structure with a timeout for each button in a big while loop?
Do I put them successively in a sequence?
Is there any example on witch I could base my development?
Thanks!
Nitrof
(2,800 Views)
Hi
I recommend you to start with the "Event structure" examples in LV. =>Find Examples=>search for "event structure". You will see four examples which can give you an introduction. See into the LV help too.
Check this link too:
http://zone.ni.com/devzone/devzone.nsf/webcategories/95A3C6B1A5A3A96386256B35005D3914?opendocument
Luca
(2,800 Views)
