Event Structure in Sub VI
Greetings!
I'm fairly new to using event driven structures. The problem I have is when it is used in a single VI to react on "Value Change: it works fine, but when I use it in a sub-VI, it doesn't work at all.
Any advise?
(5,570 Views)
You'll need to post the code (not a picture) so we can see how the rest of the VI is written.  This is not enough information to help narrow down the problem.
aputman
(5,566 Views)
Yes, please attach your code.
  • Is "analog out.out 1" a control or indicator?
  • Is the front panel of the subVI open?
  • What's in the calling VI?
  • How are you calling the subVI?
  • What's on the connector pane?
  • What's in the other events?
  • What does the VI actually do?
  • What do you expect it to do?
(5,548 Views)
this program is far too large, and too complicated to explain. I will make a simple example and send it
(5,536 Views)
The event structure on the subVI is looking at the controls on the subVI.  And it will not react to programmatic value changes (you pass data in or write with a local variable).
In general, your GUI should be done by a single loop with an Event Structure on the top level GUI.  And the timeout should not be needed in 95% of the applications out there.  Let your subVIs do one specific thing that does not depend on the GUI and then you open yourself up to being able to reuse that VI elsewhere.
(5,534 Views)
Two options, look at the examples:
  1. Use User Events to send information to the subVI.
  2. Use Dynamic Event Registration. You will need a reference to your Front Panel Control to input into the subVI.
Number 2 is probably the easiest to implement.
mcduff
(5,527 Views)
 CAN use dynamic Event registration IN A SUB-VI to register for value changes in the FP of another VI.
See here for a nugget on Dynamic Event registration.
I use that very often when I have a sub-VI devoted to a very small part of the main application.
Please note that you have to think about if and when the GUI is locked on the event and that static events are serviced before dynamics etc etc etc.
Ben
(5,520 Views)
