Event Structure with Event source: <This VI> and Event: Mouse Up
Try this.
Message 11 of 26
(1,912 Views)
Thank you! Actually I did try it that way, too, but I couldn't see the Mouse Up, see the attached screenshot. Where did you get it from? Is it copy/pasted from some older version?
Message 12 of 26
(1,900 Views)
You can wire a ref of the numeric control to get the mouse up-event and then change the ref.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 13 of 26
(1,885 Views)
/Y
That works but sounds like a bug (uhmmm, I mean "Feature")
Message 14 of 26
(1,878 Views)
@JÞB wrote:
/Y
Not having the event option in 2010 (where i checked it) can also be considered a bug, so let's call it even. 😉
/Y
Qestit Systems
Message 15 of 26
(1,872 Views)
Hi Yamaeda, if I try that with a structure freshly created in LV2012, the event input switches back to defaults, and the mouse up event is gone. I tried the same with Pauls structure, and it seemed to work a couple of times, but now -even after restarting LV- I can't reproduce it. Spooky. I tried re-wiring as well as "Link to" to switch from the slider ref (which has Mouse Up) and the This VI ref. So I still suspect that the Register for Events node somehow inherits functionality from an older LV version, until it becomes updated to LV2012. Or so...
Dirk
Message 16 of 26
(1,869 Views)
The MouseUp event for a VI reference was 'removed' (I think when they added panes).  In order not to break old VIs that use it, they just removed it from the menu choices; it still exists under the hood.  I have a (dangerous) utility that let's me mess with the properties of practically anything.  I used it to change the Register For Events node.
Message 17 of 26
(1,855 Views)
I would not mind that in a PM attachment
Message 18 of 26
(1,846 Views)
I'll think about it.  I am reluctant to post dangerous code.  It can leave LabVIEW in an unstable state.
Message 19 of 26
(1,819 Views)
Trust me:)
I understand dangerous.  PM or e-mail
I thought you had a few tricks up your sleve
Message 20 of 26
(1,806 Views)
