Event Structures and Local Variable
Hey!
I have a concern, I am doing registry and coil reading with a Modbus TCP motion control system..  Reading and writing is being done via an event structure.
My concern is: if I am creating a local variable in one case which is programmed to trigger an event for another case, should it work?  I am reading booleans from a read event case, and once a value is changed, I want it to trigger another case in the same event structure.  It is not working like I want it to. (I have it programmed under > Edit Events Handled by This Case > Value Changed)
Let me know if its possible and what I can do about it.  I am no expert in LabVIEW so layman's terms would be great :).
Danny
(2,859 Views)
Reread my message #2 in your earlier message thread.
(2,853 Views)
