07-22-2005 03:33 PM
Hi Maxime-
There isn't a method to safely route the output to a digital line that is being used as an output line without risking double-driving the line (i.e. writing a "high" to the digital line in one task and wiring a "low" counter output to the same line). Is the digital output the same as the counter output signal you're now generating on the second counter? If so you can just connect that counter output without having to worry about a seperate digital task.
Please post back if I am missing the point. Thanks to Kevin and everyone else for helping out- it seems like Maxime's application is almost ready to go!
07-25-2005 10:13 AM
