Event callback timing
When I am using dynamic events and transmit a counter as event data each time I fire the event, I can have multiple consumers that receive the identical count. Thus, only a single event is generated each time and signaled to all consumers. Ok, so far.
Now, I am using the Register Event Callback function in LV8.2. to fire events from an ActiveX component (pressing buttons on a joystick device) and use a dynamic event to signal this to multiple consumers. Again, I add a counter to the dynamic event data. What happens now is that the consumers receive different counts, even if I only click the joystick button once. As if there are multiple events generated. For 2 consumers, 2 events are being generated, for 3 consumer 3 events and so on. But how would the callback VI know that there are multiple consumers?
I tried reentrant and non-reentrant callback VIs and see no difference ("reentrant" is specified in Help, but I do not fully understand why that should be needed).
Could anyone explain this behaviour to me? Thank you!
Dirk
(3,859 Views)
Hi Dirk,
is it possible for you to post a little example, that shows the behavior (maybe by firing an event with a keybord hit)?
Bye
Daniel
NIG
(3,836 Views)
Hi Daniel,
thank you for your reply. Although I managed to include the ActiveX components supplied with my special input device, I am not in general familiar with ActiveX. Therefore, I have no idea how to find something as general as "keyboard hit". However, triggered by your reply I now tried it with a modified version of LV's example file using Excel worksheets. There, I do not see the described behaviour.
Well, I will check again on that special device driver now. At the moment, it is not working at all, which looks fishy...
Dirk
(3,828 Views)
Ok, Daniel, I found the problem. Somehow I managed to have duplicate callbacks registered at the same time... now it looks fine.
Thank's again.
Dirk
(3,824 Views)
Hi Dirk,
well, the good, old LabVIEW examlples! Hope your getting on now. Good luck for your project!
Daniel
NIG
(3,815 Views)
