Event case: number of runs of a single event ?
Hi everybody,
I'm working on a CCD acquire system, and I developed the control software using an event structure.
Every event controls a setting function for my system, and placed in timeout event fucnctions to get the status of my detector.
Data acquisition is one of the control events. Now I need perform multiple acquisition and save acquired datas to a spreadsheet file, wich must be called with the number of the iteration.
For example for 10 acquisition, the acquisition event will run 10 times, and save 10 files named: 1.csv, 2.csv ...
How can be built a counter wich gives the number of iterations of a single event (in example the number of runs of the "acquire data" event) ?
Thanks in advance
Eugenio
LabVIEW 2011
(2,672 Views)
Accepted by topic author uge026
Hi Eugenio,
Jus make a comparison for 10 times iteration. Use the value signaling property to active the acquisition event. Try this and tell.
(2,656 Views)
Thanks, value signaling vas the right choice. I've wired the increment function to a shift register function of the while loop wich contains the event structure.
Placed an indicator inside and works fine.
(2,630 Views)
