Event mouse down in an array
If I use the  the Event "Array" Mouse Down, Is there any way to know which element in the array was clicked???
Thanks.
Raymundo Cassani
(5,198 Views)
In the LAVA Code repository there is a piece of code that check that for you, it takes the current index position into account, size of the eleements.
Unfortunatly the website is currently down. Let me check later.
Ton
My LabVIEW Ideas
(5,196 Views)
You can do something similar to what I did in the toc tac toe entry as described here. Let me know of you have any questions.
(your problem is simpler, because you only have one dimension :))
(5,188 Views)
Accepted by topic author rCassani
Here's a link to the file I described.
Ton
My LabVIEW Ideas
(5,155 Views)
Thanks a lot I found very useful the VI of LAVA.
Raymundo Cassani
(5,138 Views)
