Event opens run time menu?
Hey guys,
not sure if my description is correct and I am using the right terms for what I want to achieve.
I want to have a button "custom measurement" which I can press and then a window pops up where I can insert some values for certain control elements and then press ok and the values are set.
It is comparable with a run time menu, but I dont want to use the menu bar for opening that window but a button.
Hope I could make my point clear.
kind regards
Slev1n
(3,461 Views)
Hi Slevin,
pseudocode:
IF button THEN
  call subVI (set to show FP when called and close afterwards)
ENDIF
Looks pretty easy…
(3,451 Views)
