‎08-23-2022 06:29 AM
I am writing an application and now I am wondering if it could work in a cRIO (9036).
This cRIO has the capability of the display output so I would investigate if the graphic interfaces that I am writing can be displayed.
My doubts are about two/three things:
Does anyone have experience in such subjects?
Thanks in advance.
‎09-02-2022 08:03 AM
Dear ico82,
You can write your code in cRIO as well, as long as you are programming the RT. Cannot give a certain answer, as there is no code attached, if you want to further investigate this situation you can attach the code.
Best,
Ani Shakhkyan.
‎09-02-2022 08:15 AM
Are you serious? If I want to know if the menubar works in cRIO I must program and try it and then I must ask you if it will work? In many cases it make sense to attach the code, but if my question is if some block can be used in a type of hardware it does not make sense.
However no response is already a response.
Thanks anyway
‎09-02-2022 08:21 AM
Ordinarily the cRIO is not expected to have a UI itself. I know that there are no issues with user events. You can use them to your hearts content. In terms of the UI itself I am not sure how much support you will have there. I generally create the UI as a PC application and use some sort of messaging scheme to pass data between the UI and the cRIO. I haven't really tried implementing the UI directly on the cRIO.
