Event structure in a subVI
I know this problem has been posted, but I've already am passing everything by reference. I can't get my subVI to respond to my top layer VI. It runs fine as a stand alone, but when I ask it to monitor events from a reference, it won't do anything. I've attached what my sub VI looks like. My goal is to have the the event structure respond when a new file path is sent, stop button pressed, or a enum is changed. The subVI is called Read Track shown in the top VI with all the references passed.
Top VI
Message Edited by d1sturbanc3 on 02-27-2008 12:30 PM
Message Edited by d1sturbanc3 on 02-27-2008 12:31 PM
(3,608 Views)
You should use dynamic events.
Your SubVI with the event structure should run in parallel with your main code.
What you currently have will never work.
Here's an idea of how the subVI should look like:
Try to use the Code Capture Tool to get images of your code...
Good luck,
Ton
Message Edited by TonP on 02-27-2008 07:45 PM
My LabVIEW Ideas
(3,598 Views)
Thanks... but should the even occur on the value change of Path Refnum? When the user changes watch, would that refnum change and cause the triggeR?
(3,588 Views)
havn't tried the code capture.. but I will.
I did this and it's the same issue.
Message Edited by d1sturbanc3 on 02-27-2008 01:12 PM
Message Edited by d1sturbanc3 on 02-27-2008 01:17 PM
(3,581 Views)
No, the refnum won't change.
You register for a value change event of the control referenced by the refnum!
So you are directly linked to the control on your main VI.
What do you mean by:
Ton
My LabVIEW Ideas
(3,578 Views)
The path will change, but the refnum pointing to the control will not change.
(3,578 Views)
Err sorry.. that's what I get for typing and talking at the same time. I just want to make sure the event triggers when the values is changed by the user.
(3,576 Views)
