Event structure inside while loop preventing the loop from running
Ok, so the space bar is strictly for stopping everything and then you want to save all the accumulated data to Excel?
Does is have to be a xlsx file?  I would recommend a csv file.  A CSV is a text file that uses commas as a delimeter.  And Excel will automatically open them too.  The reason I am saying to go this route is because text files are very easy to append to.  So you create/replace/open the file before your loop, format your data, and write to the file.  When the program is done, you just close the file.  I'll try to get an example coded up soon.
Message 11 of 17
(1,384 Views)
Ok, here's my quick example.  I am only showing part of the consumer loop.  I just wanted to emphasize the file write for the example.  Let me know if something doesn't make sense.
Message 12 of 17
(1,380 Views)
You may have forgotten to attach it...
Message 13 of 17
(1,375 Views)
Smiley EmbarassedThat's what happens when I'm distracted...
Message 14 of 17
(1,369 Views)
Hey crossrulz, do you mind attaching that code? I don't recognize all the VIs and having context help might be a bit faster.
xander
Message 15 of 17
(1,335 Views)
What I posted is called a snippet.  If you download it, you can copy the file into a VI and the code automagically appears.  But here's an actual VI (saved in 2011).
Message 16 of 17
(1,330 Views)
That is some black magic voodoo **bleep**.
Thanks.
Message 17 of 17
(1,326 Views)
