Event structure is missing from the Programming menu.
After defining the different cases in an event structure corresponding for different controls (present in front panel).
when i deleted a control from the front panel for whom an event case has already been defined on the block diagram.
and then when i tried to delete the case corresponding to the deleted Control from the event structure,
the Event structure is not displaying any option for add/Delete cases,
 Moreover the option to add EVENT STRUCTURE from the programming menu is mising. How can i get the Event structure back in the programming menu ?
Kindly check the attached photos for better understanding of the problem
In one snapshot, i am unable to view the add/delete case option after right clicking on the event structure.
While in other snapshot, the Event Structure is missing from the programming menu.
i have repaired the LabVIEW too
but unable to recover it.
Seeking for Valuable suggestions
Thanks and Regards
Gaurav Pal
(2,764 Views)
