Event structure tree menu?
Hi all, looking for some help for my front panel.  I have a fp button(call it 0) that when activated will unhide another 5 buttons(call them 1-5).  These are sub tests if you like.
I am wanting to know if its possible to use the event structure in a way that when the mouse hovers over button 0, the hidden buttons 1-5 appear and the user selects and the event structure would then run that particular event.  However, if the mouse leaves the button 0 without selecting, then the buttons 1-5 disappear.
I suppose i am looking for something like the Start button of Windows when you can hover on a tilte and it opens up further branches and if you dont select, it disappears.
(3,341 Views)
Erm, simple question:
Why don't you use a dropdown list?
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,336 Views)
you should be able to use the mouse enter events in order to do this.
Paul
(3,327 Views)
