Event structure
I want to execute an VI when an changement occured on my global variable.
Any idea on how I can do that with a event structure or other way ?
Thanks.
Peter.
Labview 2010
(3,918 Views)
You can use the value signaling property of a control to fire the event programatically. So you can wire the Global to a control say a boolean to its value signaling property node. I am assuming your global variable as boolean else you need use a shift register to check with its previous value and fire the event.
(3,908 Views)
I'm not sure to understand, any example please ?
Peter.
Labview 2010
(3,902 Views)
Accepted by topic author Peter Saraiva
Hi Peter,
simply test for value changes and call your subVI when needed:
(3,897 Views)
Check the attached example replace the Gloabl variable control with the actual global variable.
This explains about the Event triggering through software. But Gerd's solution is the very simple one you can go for that.
(3,891 Views)
Thank you all for your help,
Gerd's solution is more simple. Smiley Happy
Peter.
Labview 2010
(3,882 Views)
Perhaps something like this.
(3,865 Views)
