Event structures - which event is processing
Hi everybody,
I work with an event structure and as you can see in the picture I have one event case that ist controlled with multiple events: how can I control the case structure in relation with the event that is being processed at that moment?
Another explanation: when the event source is "1:" the case structure should move into "1:" case, and if the event source is "2:" then it should move to the case "2:"
Thanks in Advance
Message 1 of 11
(4,911 Views)
Can you not wire 'NewVal' into the case select terminal?
Also, if you want different things to happen for different events, I would recommend using separate event cases.
Message 2 of 11
(4,903 Views)
Are "1" and "2" controls? Then you could e.g. take the ctrl-ref from the event-"cluster" and make a property node and pick the name and feed it to your case structure.
Certified LabVIEW Architect
Message 3 of 11
(4,900 Views)
Thanks for your answer.
I cant find that property node, can you please advice me which one to use?
Message 4 of 11
(4,881 Views)
Its Label.Text. Like this:
Message 6 of 11
(4,868 Views)
You beat me to it McQuillan. Smiley Happy
Message 7 of 11
(4,867 Views)
Right click the Source terminal and create a constant.  This terminal will only output a constant that indicates where the event originated from and does not indicate which control was clicked.  Options are:
  1. LabVIEW UI
  2. ActiveX
  3. User Event
  4. Other...
aputman
Message 8 of 11
(4,828 Views)
@aputman wrote:
Right click the Source terminal and create a constant. ...Options are:
  1. LabVIEW UI
  2. ActiveX
  3. User Event
  4. Other...
I was looking at that the other day and found it odd that "Other..." while listed was not selection that would stick.
Ben
Message 9 of 11
(4,825 Views)
Sure enough.  Turn off Allow Undefined Items on the constant and it goes away.  I'm not even sure what other sources are possible.
aputman
Message 10 of 11
(4,820 Views)
