Event triggered twice when value changed in cluster
Using Labview 7.1, I've created an event handler to detect changes in value for my cluster (see attached VI). It seems to be doing something strange though... when I type in a new value for the string or number elements in the cluster, the event gets triggered twice. However, when I change the boolean element or use buttons to increment/decrement the number the event is only triggered once.
What's going on here? I thought it should only trigger the event once when changing any one element in the cluster. Is it a bug in Labview?
(3,081 Views)
I can not reproduce your problem here. It only triggers once on my LabVIEW 7.1.
(3,078 Views)
On further investigation, it seems to only happen when I enter text / a number and then use TAB to switch to the next field.
(3,073 Views)
I could not reproduce it either. Also, you may want to create value change event for a specific control, rather then the entire cluster itself.
Chetan K
Application Engineer
(3,060 Views)
Ok, thanks for trying guys. I'll try it on some other computers here and see if its just mine doing this.
(3,054 Views)
