Events in Labview 7.0
Hi all.
Can anyone provide examples of how to create programmatic (generated by the
application rather than the user) events in Labview 7.0?
Any help much appreciated.
Tony
(3,378 Views)
In the example folder there is a llb called dynamicevents.llb. This shows how to make the user defined event.
(3,371 Views)
Hi toni
 I think you must use  "Value (Signaling) Property" .
 by using this property of any control you can  create programmatic event
Behzad
(3,363 Views)
Here is a simple example (LabVIEW 7.0) for using a signaling property to fire an event.
The upper loop contains an event structure and one event is for a value change in an indicator (Yes, it does not need to be a control ;)). Under certain conditions in the lower loop, we write to a signaling property of the indicator instead of the indicator terminal and the event is triggered.
(Writing to a signaling property always triggers an associated value change event, even if the old an new values are the same.)
Message Edited by altenbach on 03-19-200608:55 AM
(3,355 Views)
