Example Code Upgrade Needed
I need help converting the following example code provided from NI from version 5.1 to 8.6.
Continuously Acquire Analog Data Using Buffers and Charting the Results:
http://zone.ni.com/devzone/cda/epd/p/id/1218
Read and Graph Binary Acquired Data from a File
http://zone.ni.com/devzone/cda/epd/p/id/2011
Thank you.
(5,801 Views)
I don't beilieve either of those two examples will work with LV 8.6 unless you are working with the old legacy DAQ drivers.
I aslo believe the shipping examples that come with LV include modern version of both of those. Try Search examples.... for examples with similar names.
Ben
(5,792 Views)
Your better off searching for current examples in LabVIEW under Help -> Find Examples. Those old examples probably use traditional DAQ instead of DAQmx.
(5,790 Views)
I am not using older drivers. I will search for better examples with what I had shipped.
Thank you.
(5,788 Views)
