Example application "Threshold And Label" error
I have licenced Vision Development Module. A have successfully activated it on my developer computer. Now I want to
1) Develop Msvc-project, using VDM functions library (functions, declared in nivision.h),
2) Build an executable application and
3) Run it on other computer, that is a part of a real vision system.
Steps 1-2 I have passed easily: I took en example project
"C:\Program Files\National Instruments\Vision\Examples\MSVC\Threshold And Label", builded application "Threshold And Label.exe".
This application works well on my developer cumputer. But step 3 fails: then I run "Threshold And Label.exe" on other computer, an error message falls out:
Can you advise anything?
(2,615 Views)
My first advice would be to put something like this to the Machine Vision Forums, rather then into LabVIEW forum when you even don't use LabVIEW.
Second advice, well it's more a question the a advice: Did you install and activate the VDM and Vision Acq runtime license on the target machine?
Christian
(2,602 Views)
