Example code for calling LabVIEW VI from C#
I'm a bit rusty about LabVIEW. Haven't used it for about three years now Smiley Sad
I'm making an automation tool in Visual C# where the user should be able to select a VI to call and setup the input and output parameters.
I must then make some VI-browser code where inputs and outputs are listed for a selected VI.
I will also have to make the code that opens and runs the selected VI.
Any hints and links could help as I havent done much "Call VI Server" or COM Interop with C# yet.
/Jan
(4,444 Views)
Hello Jan
I have a link to an example that shows how to control a LabVIEW VI through ActiveX.
[broken link removed; example no longer available]
Will this work for you...
Regards
Mohadjer
NI-DK
(4,431 Views)
