Example finder not working For LabView 7 Express
I'm using LABVIEW 7 Express Base Development System on Windows 2000.I have recently purchased NI-Vison Development Module.Everything was working fine until one day where i encountered problems with Example Finder.I could not find the reason why .When I click on Example Finder instead of showing the brwose window with options ,an open dialog box is popping up .And when i try to open with VI ...it cannot locate its SUBVI's !!!!I tried unstalling and installing again both the softwares but no use.Atlast i jus installed only LABVIEW without Vision Development Module .Even that could not help.Any help in this regard is greatly appreciated.I'm enclosing the screen shots in the attachments.
Regards
Rajesh
(2,867 Views)
Hi Rajesh,
It seems like the �NIExampleFinder.exe� has been deleted on your machine. Please check the folder �C:\Program Files\National Instruments\Shared\Example Finder\1.0\BIN� to see if it is still present.
If it is not there, you might have had a bad installation. Make sure to install LabVIEW to the default directory. Copy the content from the CD to the hard drive and reinstall from there.
If it is there, try to run it. You will get some errors, but you should be able to see the Example Finder window with all the folders.
Good luck!
Philip C.
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
(2,867 Views)
