Example for 'Get Command Line Arguments VI'
Hello all,
I have been trying to understand this VI, but I I am unable to. 'Arguments array' output is always empty. I went through the Help file, but I felt any examples makes me understand the implementation/purpose of this VI better. Can anyone share examples/the use cases of this VI. Thank you.
with regards
Adithya
(2,255 Views)
It only does something if you start the executable with command line arguments.
The executable is LabVIEW.exe, or your build application.
(2,235 Views)
Note also that if you build an application, you'll need to check a box in the build spec to explicitly *enable* command line arguments to be accessed by your program.  This box is *unchecked* by default
-Kevin P
(2,218 Views)
As a bonus, if you want to act on files being dropped on the executable while it's running, use OS Document Open and OS Document Open? events.
One of those will be triggered when a document is passed when starting the exe, the other is triggered when you drop a file on the exe or a shortcut (in Windows Explorer). These events don't require the flag in the build to be set.
(2,196 Views)
