Example in Excercise
I'm a beginner in labview.
In the training excersize from NI CD-ROM, I can't run excersize 5-5(cluster).
Please how can I connect the wire between the bundle and cluster 2.
What's the problem?
Thanks in advance.
Sungjun.
(2,891 Views)
You try to write data to a control. This is not possible. You can only directly write data to an indicator.
However, you can create a local variable of the control, to which can be written (set it to write first).
(2,891 Views)
Change the 2nd cluster control to an indicator. I have included the changed version for you. Remember you cannot directly wire a control to a control.
I hope you enjoy the rest of the course!
Kim
(2,891 Views)
