Example of Neural Network and fuzzy logic with labVIEW
Does anyone has any kind of examples of fuzzy logic and neural network built with LabVIEW?
I am particulary interested in predicting machining outputs (cutting force, surface roughnes) starting from machining regimes (parameters such as depth of cut, speed etc.). However, any example would do ...
Thank you.
Message 1 of 16
(11,423 Views)
Hello RPJ,
I've found two links that you may find helpful.  The first is NI's tutorial on on Implementing Neural Networks with Labview: http://zone.ni.com/devzone/conceptd.nsf/webmain/60594267ea31f70e86256ae300813841 .
The second is some example code which is just a rough example of a Neural Network Learner: http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3EDBB56A4E034080020E74861&p_node=DZ52000_US .  It is fairly old, but should still be relevant.
I hope this is helpful!  Good luck,
Megan B.
Message 2 of 16
(11,398 Views)
Thank you Megan.
Radu
Message 3 of 16
(11,388 Views)
Hello, the example (mentioned above) is in a very old LabVIEW version. How can I open it in LV 8.5 ???
Thanks.
Lukas
Message 4 of 16
(10,910 Views)
Hi Lukas,
You can open a 4.1 version VI/LLB in LabVIEW 8.2 and save it there. And then you can open that file in LabVIEW 8.5. Here is a link that lists the different versions of LabVIEW and the versions they can be loaded in.
I have converted the neural files to LabVIEW 8.5 for you.
Hope this helps!
Warm regards,
Karunya R
Message 5 of 16
(10,887 Views)
Karunya,
That's nice of you.
Coudl we have the updated files or links?
Thank you.
Message 6 of 16
(10,885 Views)
Sorry. I thought I had attached them the last time
Warm regards,
Karunya R
Message 7 of 16
(10,881 Views)
Warm regards,
Karunya R
Message 8 of 16
(10,879 Views)
Karunya,
The attachements showed this time - thank you.
However, there are a lot of llb files (sub-vis I believe) missing and the applications cannot be run. You might want to save the examples as a library or make a project and zip the whole thing... ?
Just a thought.
Message 9 of 16
(10,876 Views)
More apologies.
The zipped folder is in 8.2. so you shouldn't have a problem opening that in 8.5.
Warm regards,
Karunya R
Message 10 of 16
(10,871 Views)
