Example of Qt dll running in LV
 Hi, folks. I'm working in a project where I need to build a dll using Nokia Qt system and further run this dll fuctionality in a LabView application.
 Under an enthusiastic wave I attempted to build and run the whole library. Obviously I gratefully failed...
 So, I decides to start little by litte and I tryed to build and import a very simple dll application in LV. I attached the sources of the library and a simple program that I used to test it. The vi was not attached becouse is justa has nothing in it, once I tryed to load the library by Tools -> Import -> Shared Library (dll) menu.
 Stated that way, I want to ask if someone can post here a simple example of a Qt library running in LV or if one can tell me what is wrong in my library project.
 Thanks so much
Leo
(4,679 Views)
Take a look at the link below, and you may find or ask for useful information.
http://forums.ni.com/t5/BreakPoint/LabVIEW-vs-Nokia-Qt/m-p/1100920?requireLogin=False
Thanks.
Best Regards
Luciano Borges
Test Development Engineer
(4,664 Views)
