Example of linked node bug
I think that a couple of very simple UI improvements to the linked tunnels ability would be great.
1 - when you click create and wire linked nodes, the cursur becomes a solder iron, and annoyingly the scroll bars stop working - this is annoying if you have a large case structure.  So firstly should allow scroll bars
2 - another simple tweak would be to allow a quick jump to the other side of the case structure - since this is typically wheree you are connecting.
3 - once a linked node is created, if the link is broken, then in order to rewire it you have to 'create and wire linked inputs' again - even though it knows where the node is.  Would be nice to have another option - to wire to the already linked node.
Example attached.
(2,614 Views)
I was about to point you to the Ideas Exchange but then I noticed that you had already posted this on there.
The Ideas Exchange is a much better place for this suggestion to be (as you can see from the comments that you have).
For others who view this post here is a link to it's sibling in the Ideas Exchange
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Linked-Tunnel-Node-Gui-improvements/idi-p/1905295
James W
Controls Systems Engineer
STFC
(2,578 Views)
