11-26-2008 06:22 AM
we develop our application in Labview 8.1 under Linux. Now I want use the "FP:Transparency" but it dosn't work.
I found the example "TransparentVI.vi" and it also dosn't work under Linux (the example is running without problems but there is no change in the transparence). I test the same example under windows and there it work.
Why it work under Windows but not under Linux?
Can somebody help me?
11-27-2008 10:23 AM
Hello MSD,
at the moment transparency isn't supported under Linux. But, Linux will simply ignore the property node, therefore if you have a working VI under Windows that uses transparency it will continue to work under Linux without error.
Sorry for this "bad" news.
Best wishes, Jan Kniewasser
Application Engineer, Munich
