Examples of use with IMAQ ROTATE and IMAQ PATTERN MATCH or IMAQ FIND PATTERN 2
In the following function block proceed to perform the extraction of the pattern with a function for image processing that captures the last event of the RGB (extract image and coordinates)
Message 11 of 12
(624 Views)
In the following we proceed to function block search pattern extracted in the previous process (the parameters as rotation angle and minimum score is inserted into SETTINGS control), extract the output of the search function to get the position values indicators that will be displayed on the front panel)
Message 12 of 12
(623 Views)
