Exaprom authorization
hello,
has anyone ever tried to make limitation with exaprom library (such as authorization of print - reading, password, ...)
thank you
Message 1 of 17
(4,961 Views)
Hello Jacouille,
I think this might be worth a look:
https://decibel.ni.com/content/docs/DOC-10952
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 2 of 17
(4,916 Views)
I know the module exaprom.
I added in the "New PDF" module a reference "PDFWriter - setencryption"
I can introduce different values for the "ownerPassword", the "userPassword", the "strength" can be either true or false.
But I do not know what value to change permissions.
On the net, I found some information (see attachment) but I do not know how to implement.
thanks for your help
Message 3 of 17
(4,905 Views)
Hello Jacouille,
Where are you exactly stuck?
Based on this VI and your documentation you just have to specify each of the bits of 32-bits signed integer called "permissions".
What these 32 bits should be is documented in the pdf you posted.
If something is unclear, then please let me know.
Kind Regards,
Message 4 of 17
(4,895 Views)
Hello ThiCop,
The error came that I had to reverse the order.
I have another problem :
When the PDF file is not protected everything "set up" as I wish text, picture watermark, ... .
When the file is protected, some elements are not introduced into the pdf file and I get an error 1172 (see attachment).
The problem seems to come from the PDF stamper.
Message 5 of 17
(4,876 Views)
I forget to attach the pdf file
Message 6 of 17
(4,875 Views)
Hello Jacouille,
After a week in Finland I'm now back at the office.
I seem to be not able to open your VI based on the library mentioned here: https://decibel.ni.com/content/docs/DOC-10952
Are you using the same version, because there appear to be some differences in naming and some missing VIs.
Kind Regards,
Message 7 of 17
(4,847 Views)
Jacouille,
If you are willing to post your VIs (LV2009), I could take a look at the end of this week.  Because we both speak french, it will easier if we continue this post in the french board.
JM
Message 8 of 17
(4,833 Views)
Hello J-M,
I guess you wrote the palette based on your name.
His VI's can be found a few posts higher.
There however seem to be a few missing VIs or renamed ones compared to your original post.
Kind Regards,
Message 9 of 17
(4,817 Views)
Yes,  I wrote the palette.  Unfortunately, his VI's are in LV2012 and I only have LV2009.
JM
Message 10 of 17
(4,809 Views)
