Excel 2010 and labview 2010
I think this may have been covered, but has anyone noticed any differences in the ActiveX properties or methods in labview when working with excel 2007 as opposed to excel 2010? I know at one point Microsoft had changed a few things from excel '97 to '2003 and instead of selecting "value" in your method, you now have to choose "value 2". Does the same hold true for excel 2010? I am currently using excel 2007 at work and 2000 at home and when I open my code at home, my invoke nodes "have bad wires" yet all required inputs are correct. Same code on excel 2007; no bad wires and the code will run. I am just curious if anyone has tried to use labview 2010 and excel 2010 together and did it work? I'm opening 1 workbook and writing to 4 different excel sheets using WinXP, excel 2007 at work and have windows 7 and want to use excel 2010 at home and would prefer no problems or at the very least know what some potential problems are. Sorry if this confusing. I think this is the best way I can explain it as I haven't gotten MY head wrapped around it yet.  I just don't want to write the same code twice for the different versions of excel. (write and test at home, then re-write at work)
http://digital.ni.com/public.nsf/allkb/177D720A428CA72B862567EC00757F0C
this is one example of what I'm talking about
Message 1 of 17
(5,960 Views)
Accepted by topic author Myke
Myke,
While I don't have excel 2010 available to try-and-see, Microsoft (and MSDN) has a huge amount of information regarding calls in all versions of Excel.
Excel 2010 development resources: http://msdn.microsoft.com/en-us/library/ee658205(office.14).aspx
Excel 2007 development resources: http://msdn.microsoft.com/en-us/library/bb979621(v=office.12).aspx
Hopefully this helps you get started, as I do not have access to excel 2010. Let me know if it works for you.
Kyle Mozdzyn
Applications Engineering
Kyle M.
Message 2 of 17
(5,931 Views)
Kyle,
Thanks for the response. While reading all that stuff on those website is alot like tracing the flight pattern of your average housefly, I did manage to make sense of some of it. I think it will work and I'm about to buy a copy to office 2010 to try and prove it. There were some improvements to excel 2010 but they shouldn't affect how things get called and referenced.
Myke
Message 3 of 17
(5,925 Views)
Myke,
Glad that was able to help a bit. Some of the MSDN stuff is quite hard to follow/over my head, but glad you were able to make sense of it. Best of luck, and please keep us posted on compatibility.
Regards
Kyle Mozdzyn
Kyle M.
Message 4 of 17
(5,905 Views)
Will do. hopefully I won't run into too many problems if any. I hate to just ask questions and not help, so here's my chance. LOL
Message 5 of 17
(5,903 Views)
Kyle,
since we are talking about calls, methods, and such, I was wondering if you or someone else could take a look at this code and see what I'm doing wrong. The program itself was much bigger at one time, I think I may have narrowed it to this because I keeo getting a write to excel error. I'm using winxp, office 2007 and reading from a .CSV file to simulate data gathering. on the csv sheet for the ranges are B849:N866 for the "floor" skipping over two sheets and using D850:L865 for the "right wall". then of course I am using just a simple range to write it all to the sheet(s).
stacking.csv is where the data is coming from
WFC automation sheet is where it's going.
Message 6 of 17
(5,878 Views)
here is the other that goes with it that is where the problem is.
Message 7 of 17
(5,877 Views)
Myke,
I took a look at your code, and the issue is coming from when you close the 'sheets' reference before using it again, making it an invalid reference. Deleting the red-boxed close reference will fix the issue.
After doing that, youll get a second error for invalid reference (also boxed in red), which is because sheet 4 doesnt exist.
Hope this gets you what you want.
Kyle Mozdzyn
Kyle M.
Message 8 of 17
(5,843 Views)
Kyle,
Thanks for looking at that. I guess I just got a little happy with the close reference function. I'll try it and see what I come up with.
Message 9 of 17
(5,795 Views)
Ok Kyle,
I did what you suggested and it worked beautifully, even writing to sheet number 4 on the wfc automation workbook. I'm uploading a pic and the red box and line are the pieces I got rid of and did a little rewiring.
BTW, I got my copy of office 2010 and will be installing it in a day or two. I'll post anything that I find and or notice.
Message 10 of 17
(5,788 Views)
