Excel 3D Bar Stacked
Spoiler
how can i change the Diagram (3D Bar Stacked) from horizontal barto vertical bar?
Thanks for any help
Mändy
(3,156 Views)
Hi Mändy,
If you switch the constant "xl3DBarStacked" to "xl3DColumnStacked" that should do the trick.
Is that what you want to achive?
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
(3,091 Views)
Yes,  thats it.
Thanks a lot Christoph!!
(3,077 Views)
You're welcome Smiley Happy
That's what we are for!
(3,073 Views)
