Excel ActiveX control
I am trying to run an example code and I receive the following error:
"Error -2147319779 occurred at Library not registered.
in Excel - Write Table.vi"
LabVIEW Example Code: C:\Program Files (x86)\National Instruments\LabVIEW 2018\examples\Connectivity\Excel\Excel - Write Table.vi
This error is thrown at the Automation Open function. What libraries do I need to register to get ActiveX references working correctly?
LabVIEW 2018 : 32-Bit
Microsoft Office 2010: 32-Bit
Windows 7: 64-Bit
(9,118 Views)
Well, I generally use the Report Generation Toolkit (which you might not have), so didn't expect much from an ActiveX Example.  I ran the same example (Excel - Write Table) using LabVIEW 2018 (32-bit) on Windows 10 x64 and Excel 2013 (64-bit).  I don't know what element makes the difference, but for me, the example worked.
Bob Schor
(9,087 Views)
Thanks, but I need to use the Automation Open function. Any other advice?
(9,046 Views)
I assume you have checked the obvious... excel is installed?
I also assume you have followed the instructions in the block diagram...
The example also works for me on LabVIEW 2016 (32-bit) on Windows 7 x64 and Excel 2013 (64-bit)
Good luck.
Former Certified LabVIEW Developer (CLD)
Currently using LabVIEW 2022
(9,035 Views)
Hmm.  I looked at the last two Posts, and thought about this again.  I was first curious about the comment that the Original Poster needed to use the Example and the Automation Open function, so I thought "Well, maybe he (or she) doesn't have the Report Generation Toolkit, so has to use ActiveX directly."  I verified that the Example works for me, but then decided to understand Frozen's note that references finding the correct ActiveX class.  So I tried to do that.  I right-clicked on the ActiveX refnum, chose Select ActiveX Class, and tried to find the Excel._Application refnum.  I couldn't -- there are hundreds of Type Libraries, each with numerous entries, but nothing (obvious) under Excel, Office, LabVIEW, Microsoft, ...  I was able to find an Excel._Application, but I got it by "cheating" -- I used the function in the Report Generation Toolkit that returns Excel ActiveX references, including _Application.
Bob Schor
(9,026 Views)
Accepted by topic author Albyeh2
It looks like Microsoft Excel 8.0 Object Library was missing from the 2010 Microsoft Install. Re-installation of 2010 did not solve the issue, so I had Microsoft Office 2013 installed which seems to have fixed the problem. There must be an issue with the 2010 Microsoft Office Package that is being installed.
(9,007 Views)
