Excel Chart Header/Footer
I am having a really hard time trying to write to the chart header and footer using Active X.  I have an excel file that I want to use as a template to write my data to.  In this file I have some sheets and some charts that have their source data tied to a sheet and the cells on the sheet.  I can write my data through Active X to the sheets and enter my header and footer without a problem.  I can even select the the charts and print them, but when I try to write headers and footers to the charts nothing happen.  I get no error messages or anything.  I currently select the chart and then use the PageSetup property to write to the header information just like I am doing for the individual sheets, but for some reason this does nothing.  Also I tried changing the chart title and stuff like that and I get nothing too.  Can anyone tell me what I am doing wrong?  I can't seem to figure out what I am missing.
(4,834 Views)
Hi tct1375,
Could you post a snippet of code that shows what works with the worksheets, and what's not working with the charts?  Thanks!
James R.
(4,807 Views)
Sorry for the late response, my code are on my computer at work so I couldn't respond over the weekend.  Here is a copy of the spreadsheet and the code I use to write to the sheet's header/footer and the code for writing to the chart's header/footer.  Please let me know what is wrong and if you need anything else from me.  Thank
Tom
(4,787 Views)
To modify the chart headers and footers, I had to change the numeric control (input into the Sheets method) into a text control and transform that "To Variant".  Then, upon using the Print Preview feature of Excel, I was able to see the header and footers I had chosen.
James R.
(4,767 Views)
Hi James,
Thank you for the information.  I tried what you said but it doesn't seem to work still, like before it looks like it opened the file but doesn't do anything to it.  Maybe I am doing something wrong still, can you post the modification you made?
Tom
(4,748 Views)
James,
I'm an idiot.  The code has been working all along.....just that I had to save the workbook.  I was just opening the workbook afterward and that is why the changes never showed up.  Everything is working fine now, thanks again for helping.
Tom
(4,744 Views)
Hi Tom,
 Can you share the troubleshooted code? I'm facing some issue on creating footer in excel sheet.
Thank in Advance,
Hari
(1,840 Views)
